Is this ok to install the doorframes on top of laminate flooring. I had a slight issue with lintel height in my opes for my doors (see previous thread) and need to build it up some. I also have 2100mm high pre cut frames and if I install the frames on the screed, then flooring I can lose 18mm which I badly need for the height.
If I install all the flooring first throughout my extension, through all the opes and the frames on top, will I have any issues with expansion if install like this.
