Domino's too loose
ScouseKev
29 Jun 2011
South Liverpool
I bought a Domino with the 2nd sustainer case full of Domino's.
Ive used all the 10mm ones and they fitted great, ....ordered some more 10mm from a reputable supplier and they are too loose.
They are fine on the width, but loose on the 10mm thickness.
I checked with a vernier and the original ones are 10.1mm and the new ones are 9.98mm.
I'm making a table and the joint is really quite wobbly between the apron and the leg.
Have i just got a duff batch ??
I normally find domino's too tight if anything, never had any too slack. I always presumed once the bag has been opened they absorb some moisture and swell up.
Doug
Doug
And what's more to the point they swell even more when glued, so I wouldn't worry about it.
Jim
The glue will make them swell up don't worry. I had to put all of an opened bag, nearly 600,of 5mm in oven as they got damp and were nearer to 6mm
