Evening All,
A year or two ago we had a combi boiler installed, fed from a new pipe run straight from the gas meter. The existing gas pipe (under floor) remained in use for the cooker.
Fast forward a bit and we've found a gas leak from the old under-floor pipe. We called out National Grid and they confirmed the leak, then condemned the under-floor pipe. As an emergency measure, the old pipe has been disconnected from the meter and capped off so that we can use the boiler. Obviously this has left us without the cooker.
The combi is located not far from the cooker, albeit upstairs. I called in the (local) firm who installed the boiler, and inquired whether it would be possible to tee off from the boiler to feed the cooker. They responded by saying it's possible, but a bigger pipe would be required from the meter to the tee to allow for the combined draw of the combi and the cooker. That sounds plausible to me. The trouble is, they want £500ish for the work! The new pipe from the meter to the tee would consist of four elbows and five straight runs, all easily accessible. The new run from the tee to the existing cooker pipe is probably four or five straight runs, again nothing too complicated. Is 500 quid for this reasonable? I appreciate that I'm paying to have a qualified gas fitter for the day, rather than the actual work involved.
Just to muddy the waters a little, SWMBO is lobbying me to sack off the gas and just get an electric cooker instead. Of course it goes without saying that there's no circuit installed for the cooker, and every bay in the consumer unit is already in use.....
