woodbloke
I've had my existing dogs on this bench for around 10 years or so and they're now getting a bit worn and scabby...so I've just made some new ones!
The old ones on the left are the original, spring-loaded Krenov style ones that can be found in one of his books...not difficult to make but these would only stay about 15mm or so above the bench surface, whereas the new ones will stay a lot higher, useful or holding taller stuff like boxes etc.
But they can also be set at any height needed:
...as well as going completely flush with the bench top. In order to do this miraculous feat of woodworking I've pinched an idea that I saw at Pete Sefton's bash last year...
...and inserted a couple of sprung loaded ball catches. You don't need any special timber to make these, but I just happened to have a lump of Wakansian rosewood :mrgreen: (hammer) under the bench that was almost the right size. What's even better is that apart from working fantastically well, you don't need to spend the equivalent of Greece's debt on fancy Veritas bench pooches - Rob
