A
Anonymous
Guest
is it recommended to use a pilot hole in soft woods i.e pine?
Cheers,
Derek.
Cheers,
Derek.
I have a cheap set from Screwfix of this type. They are a collar that clamps on a normal drill which cuts a counter bore and counter sink, I use them most times I use screws, they work well.Steve Maskery":35n1k32g said:If you can clamp the two together, those special drills that do pilot/clearance/counterbore all in one go are worth a go.
