Do I need a new start capacitor?
stewart
16 Jan 2005
Sussex
Hi all
Happy New Year!
My Sip 10 inch cast iron table saw that has been so reliable for over 10 years, has developed a problem with starting. When I press the start button there is a humming sound from the saw and the blade attempts to move but never gets up to starting speed. With the switch then turned off, if I rotate the blade by hand ( I use a stick really!!!), it does then sometimes start and get up to speed slowly but there is a burning rubber smell - so I switch off immediately. I am no motor expert (or even amateur) but having researched this I think the start capacitor might have come to the end of its life. Before I buy a new one, though, (over £80 on Sip's site...) am I on the right track?
I know nothing, except that these things are pretty generic and if you can identify which one you need, they can be purchased for a fraction of that.
It could be a start capacitor, have a look at it and see if it's obviously damaged, they often split open. If it is damaged any make of capacitor of the same type and spec should be fine. I bought one from Maplins for my belt and disc sander, cost about £8 I think. If it's not the capacitor it could be the start switch.
Thanks, Nick and Woodpig. I'll have a look at the capacitor and see if it looks damaged. Good place to start...
Thanks again.
Also, the bottom of the capacitor should be pretty flat. If it's 'blown' like an out-of-date yoghurt, that's another good sign that it's fubar.
Is there a red faced emoticon? [FLUSHED FACE] no need for a new capacitor...problem was a small piece of oak stuck between the drive belt and frame of saw...
[/IMG]
My start capacitor failed on my table saw recently and i replaced it with one from maplin for £8. However, my previous capacitor showed no sign of damage. It was just my first option to try to repair it, and as happened it worked and i have had no problem since (my saw is used daily so it has had a lot of use since the change).
Just to let you know if you are not sure. The capacitor from maplins has 4 connectors. You only need 2 connectors, there is a big line dividing the 2 sets of connectors. You must have one wire fitted above the line and one below. It makes no difference which way around they go, but you will get a big bang if you wire 2 above!
I got no instructions so i rang the manufacturer of the capacitor to get the above information.
Nick
Easily done, and a cheap fix.
Anyone who says they've never done something similar is a liar (or has never done anything). :mrgreen:
I know...my wife said that it had saved me £80...so what should I spend this saving on??? :D :D
Spend 78 quid on women and drink, then waste the other 2 quid on tools.
I'm not sure if want to spend it on a £78 woman, you know the old saying, you get what you pay for!
