Display cabinet plans
Sailor
13 Nov 2005
Evening everyone,
SWMBO wants a matching pair of wall-hung display cabinets to show her collection of antique hand-bags.
I reckon they need to be approx 3ft high, by 2ft wide or so.
As they require glass fronts, I'm concerned about the weight of the glass on what will be quite shallow bases, (built of Maple with probably Maple ply backing).
Is there such a thing as 'lightweight' glass for situations like this? Or alternatively, anyone ideas for hanging the doors without having overly large hinges?
Many thanks,
Colin
jasonB
26 Nov 2004
Surrey
You could use picture glass that is 2.0mm thick or just 3mm float. I have a cabinetfor some of my model figures, the doors are 600x900 and made from 58x22 finish size pine hung on a pair of 50mm brass butts. Silicone the glass in all round for added strength. I used 3mm glass.
The doors also have a groove all round the inner face to take a rubber seal which keeps the dust out and there is a 450mm flurescent tube in the top of each cabinet.
Or you could have frameless doors like Thisor This
Jason
Sailor
13 Nov 2005
Jason, thanks.
Your's is the style I was thinking of. The frameless types to my mind, appear more likely to be 'store-bought' than self made. For some reason, I had been thinking that picture glass could only be used in a permanent fixed frame, I don't know why!
I like the idea of the dust seals - is your cabinet from a readily available plan? because if so, that would really help me.
Thanks,
Colin
Kurt Loup
23 Jun 2005
Baton Rouge, LA USA
Colin,
I don't think you will have to worry about the weight. I was worried about the door being too heavy on this cabinet I built. The door is approximately 22" wide x 6'6" tall. I used 1/8" glass.
Kurt
More Pictures
http://www.loup-garou.net/rodcabinet.html
SimonA
24 Feb 2004
North East
Hi Jason,
Could I ask where you got the frameless hinges for the glass doors?
SimonA
jasonB
26 Nov 2004
Surrey
Simon
The small corner cabinet has hinges that fix to the glass with nylon grub screws and can be bought from Woodfit
The oak unit has hinges that require a 25mm hole to be drilled in the glass and can be bought from Woodfit or Isaac Lord
Jason
