Hi Everyone, This is my first post on this forum. I apologise if this has been disgust before, but I cant work out how to search the forum. I have recently got hold of the Dewalt DW1251 radial arm saw and during refurbishing it, I have noticed that the saw blade wobbles from side to side. Also, if I drop the blade down so that it just touches the table surface, and then spin the blade by hand, it moves away from the table and then comes back in contact again. I took the blade off and used a dial gauge against the motor spindle, which confirms my suspicion that the spindle is bent by 0.127mm. Now, I know that doesn't sound much, but by the time you translate that movement to the teeth on the blade, the movement is visible by eye. I am wondering if anyone on here has had the same problem or if you know of a scrap machine that has a working motor. The other question I have is, does anybody know how to identify the model type for these machines? I have seen on the parts diagram "Type 1" and I need to know how to find out what mine is. Many thanks for your help!
