Denford Viceroy TDS 6 SB Sanding disc
Morty
26 Dec 2020
DD11 4QS
Just bought a 3ph Viceroy TDS 6 SB to do mainly bowl turning and am short of an outboard sanding disc either 12" or 14" would suffice, 1.25" x 9tpi LH thread, can anyone help or point me in the right direction to find one
Phil Pascoe
29 Jan 2012
That's just about the most unusual thread used, so you're unlikely to pick up a disc designed for another lathe. If you have a faceplate you could mount a piece of MDF and either stick a velcro disc to it and use velcro backed abrasive or sheet abrasive straight to it and treat it is as sacrificial.
Morty
26 Dec 2020
DD11 4QS
Thanks Phil, it came with RH faceplates but nothing for the LH out board spindle, might look at having an alloy disc made if nothing turns up. Nice bike
Reginald
27 Feb 2021
I made my own using one of my outboard small face plates and a aluminium disk
