Delta Tenoning Jig
Mdotflorida
7 Nov 2003
South Wales
Hi Waka
He's asking pretty much full price for it as far as I can see. I paid £100 for mine from the same guy who imported my Unisaw.
Jeff
Waka
8 Mar 2004
Weymouth
Anybody got any experience with the Dakota tenoning jig?
Might just be the pictures but I feel the Delta one looks a little more robust, mind you I'd be happy to be proved wrong.
Who was the guy jeff.
llangatwgnedd
17 Sep 2002
Castell Nedd, De Cymru
Name: Dave. Rating: 5/5
Am very impressed - it's probably better than Norm's. Easy to adjust, rock solid, holds its settings, built like a brick outhouse. Needs modification for Jet Supersaw (possibly others) - but easy and well worth it. Slider bar needs moving - simply drill two extra fixing holes in the baseplate to move the whole jig about 2 inches closer to the blade. (Drill one hole, attach the slider fairly tightly, fit to the saw and adjust for precisely parallel travel, carefully slide off the saw without moving the slider bar, mark and drill the second hole.) Can highly recommend it - much safer than home made kit, and you'll get dead easy, accurate tenons every time. Move over Norm!
Just a small review from one person who have purchased the Dakota version from Rutlands .
Anyone else purchased the Dakota Tenoning jig as I am also interested in it ?
Noel
Moderator
Staff member
Moderator
7 Aug 2003
Does this Dave bloke work for Rutlands by any chance?
Noel
Alf
22 Oct 2003
Up the proverbial creek
Cynic :D But how he can give it 5/5 when he practically had to rebuild the thing I don't know. Presumably it's not mentioned anywhere else that it might not fit certain saws without modification? I'd look for myself, but Rutlands isn't particularly Firefox friendly so I don't visit their site if I can help it. (It's a pathetic protest, but mine own. :roll: )
Cheers, Alf
Mdotflorida
7 Nov 2003
South Wales
Cheers, Alf
The Delta jig that I have did not fit my Unisaw straight out of the box either. This was due to the fact that the jig was set up for a right tilit blade and my Unisaw (and the Jet SS) is left tilt.
The Delta jig however was pre drilled for a left tilt blade and just required a bit of unscrewing and reassembly which was covered in the instructions.
5/5 for something you have to re-engineer is not being objective.
Jeff
SlimShavings
25 Dec 2004
Tennssee, USA
I have the delta version for about 10 years now. USe it with a dado blade. Knife the tenon(to reduce chipping) and cut each side one pass !! :lol: :lol:
martyn2
5 Aug 2005
poole dorset
Philly":2wwipias said:
Waka
There was a recent group test in FWW-they were pretty much all exactly the same with different badges, so shouldn't be a problem. Dan's email is [email protected].
Philly :D
I had a reply from Dan he no longer imports the jigs so i guess i have got a couple of choices Make one (I have few good books on jigs, woodsmith from timelife) bid on ebay or wait until october so many choices so little time
martyn
Ian Dalziel
13 May 2004
Scotland
Not hard to make your own......plans are in GWW issue ???/ can someone help.make it in a heavy hardwood and do make a guard.....works better than the delta......
Ian
DaveL
19 Oct 2002
Sudbury, Suffolk
Its pages 30 to 35 in issue 151.
If you cannot find a copy, PM me I may be able to help. :)
I have not made one, I bought a second hand Delta on ebay from the states last year. :roll:
