A friend has recently bought a new David Wilson '5 Star' Homes 3 bed house with ensuite shower room and fitted with a combination boiler.
After about 2 weeks the whole ground floor flooded due to a 22mm plastic elbow on the rising main blowing apart in the kitchen ceiling void. They blamed this on water pressure too high, then a dodgy fitting.
Following several weeks using specialist equipment to dry the screed out again, they are now in the process of replacing dry lined walls, bit of ceiling, kitchen, doors, flooring, etc. Unfortunately yesterday they had another leak which means more drying out.
They've now chopped into the walls and cut large holes all over the kitchen and utility room ceiling and replaced all 22m plastic pipe with 15mm from the mains stopcock onwards, including that in the ceiling void.
From my limited plumbing experience (admittedly with roof tank, immersion heater, etc) I've always used 22mm pipe from the stopcock, with 22mm going to the bath, roof tank, and branching off with 15mm for sink, basin, etc.
Before I make a fool of myself, please could anyone with more knowledge tell me if they think 15mm from the stopcock under the sink onwards is ok? Is it likely to be noisy? Will they be able to fill a bath and use the electric shower at the same time? Any other possible drawbacks?
Many thanks in advance for any replies.
Graham
Graham
