Danish Oil
A
Anonymous
Guest
Would Danish Oil be a good finish for a staircase Handrail?
Cheers,
Derek.
Sgian Dubh
12 Oct 2004
UK
Derek, as a follow up to your earlier question on the handrail subject, danish oil along with all the others of that type such as teak oil, okene, tung oil finish are all a form of varnish, soft and fairly easily damaged varnishes, but varnishes all the same. Put enough coats on and you'll get reasonable protection.
As before I'd recommend using regular interior varnish, either oil or water based, but you should note the reservations I mentioned previously about the performance of water based polishing products. Slainte.
trevtheturner
26 Feb 2003
Herefordshire, UK.
Derek,
I have used oil-based interior varnish on hardwood handrails. I applied several very thin coats, flattening with 0000grade wire wool then clean-up with tack cloth between coats. Excellent result - five years on and still as good as new. (But don't use wire wool on oak - use a fine abrasive pad instead).
Cheers,
Trev.
