Danish Oil problem.
Robbo3
28 Jan 2012
Oxfordshire
Bought a can of Rustin's Danish Oil from Axminster PTC last November but didn't open it until recently. Best description I can give of the smell is rancid, ie not the pungent Danish Oil of old which you could still smell three days later.
Even the replacement oil only has a feint aroma like it used to be but it did soak into a small piece of oak that I had turned & then submerged. The old oil looked like a surface layer of thick varnish with sags & runs.
Anyone else had this problem?
Axminster immediately replaced the product, offered an apology & told me the old oil was mine to do as I wished with as it wasn't cost effective to return it.
I emailed Rustins with all the numbers that I could find on the can, just in case they had a bad batch, but didn't hear anything back from them.
Jacob":3r8l4z39 said:
You probably just need to give the tin a good shake.
I probably don't. :)
Extract from the waffle email from Rustin's in reply to my query,
"It has been generally accepted that Rustins Danish Oil is what it is, virtually what is known as a heritage-class coating, produced from the same kinds of natural substances that long-dead artists such as Leonardo DaVinci would have been quite familiar with."
Some 'well shaken' Danish oil decanted into a jar. It doesn't show the true wishy-washy light coffee colour.
    70.5 KB
Looks OK to me.
It might be worth looking in the tin - I seem to remember waxy stuff settling out, maybe frost or sheer length of time. In which case it could need warming as well as shaking - stand the tin in hot water don't try direct heat or you could get a big explosion.
