whybob71
Hi guys
does anyone have never used a dado blade on the TS2500ci table saw?
whybob71":3k7pv949 said:...than if I have the "special nut" can I use a standard dado blade??? :? :?: I'm confused......
whybob71":kxnko8xq said:which size of cuts is able to perform the sheppach special cutter?
andy king":kxnko8xq said:Its the dado head that will probably gain most favour, the saw will take a 8mm-15mm shimmable set, costing about £100, but the SUVA guard is about £450, so the chances are either a home made one will be used, or totally disregarded, making it a little more fraught with danger when used.
