D3 or D4 glue for Outdoors
Osvaldd
29 Sep 2018
NI
Hi, was wondering for outdoor projects like chairs and tables and stuff, is D4 type glue necessary?
I have almost a litre of Everbuild 502 D3 glue which I want to use up, but don’t want to end up with failed joints if its not suitable for outside. It says its weatherproof but not waterproof.
Eric The Viking
19 Jan 2010
Can you arrange it so that the glue isn't doing all the work, for example with drawbored dowels?
I have built very little for outdoors, but I made a stand for the tomato growbag that was glued up with Titebond 2 and used drawbored tenons. It's out in all weathers and probably six or seven years old now, with no sign of failure, although the adjustable metal feet had to be replaced last year because they rusted. That was partly because the posts have such large shakes in them (as built) that rainwater could get to unprotected bits of the foot assembly. The feet were fine, but the threaded inserts weren't.
RobinBHM
17 Sep 2011
Wst Sussex
I would choose a PU glue for external use.
Although big joinery manufacturers often use pva.
I seem to remember being told the difference in spec is the boil time test, between D3 and D4 glue
For a home project its not worth the risk.
Doug71
28 Aug 2016
Yorkshire
I would go for PU, there is something about the fact it takes a week for the black marks it leaves on my hands to wear off that makes me think it sticks stuff together well #-o
Steve Maskery
26 Apr 2004
Kirkby-in-Ashfield
Outdoors, D4 every time.
Toolstation now do a D4 hybrid that looks like PVA rather than honey and it's not very expensive.
will1983
14 May 2014
Crewe
Everbuild D4 for everything in my workshop.
Only £8.14 for a litre in Toolstation!
Phil Pascoe
29 Jan 2012
:D I saw that link somewhere else and when I tried to find it on their site I couldn't. I need some 12mm glue sticks soon so try to watch their special offers.
Cordy
1 Dec 2014
Wigan
Osvald
….for outdoor projects like chairs and tables and stuff,
This outdoor chair was made 4 years ago; glue was D4
Used often and still as strong as day one :)
Cordy
1 Dec 2014
Wigan
Forgot to mention that I now use Cascamite for projects made for outside :)
Osvaldd
29 Sep 2018
NI
@Cordy
That chair looks well protected by the paint I would not worry about waterproof glue in that situation. tbh
woodbloke66
17 Sep 2018
Salisbury
Yep, fantastic stuff. I use it for just about everything (inc exterior work, but not boat building or similar) but you're paying over the odds for it; I can buy it locally for less than a fiver - Rob
