Cyclone Dust Collection
Big Al
26 Jun 2013
Sheffield
Comsidering a dust collection system with a cyclone unit.
I already have a Record dust collector on my table saw but considering a cyclone system on my router and other power tools.
Anyone any experience of these units?
there are so many options and most look as if they are the same product with a different label.
One thing I have picked up from on line videos is to use a steel drum not a plastic drum.
Any information or advice would be much appreciated.
Doug B
Shy Tot
6 Aug 2008
@dougsworkshop
This is my cheap cyclone cone bought off eBay
It came from China as you can tell from the writing, it was the mark 3 which I believe is to do with the shaping of the inlet, the curve on the top, that said I also have an original Oneida dust deputy which must be 13 or 14 years old now that has an inlet pipe that goes straight into the side of the cone & both seem to work equally as well as one another, so I don’t think it really matters that much & whatever you get will be infinitely better than not having one
DBT85
19 Dec 2015
Pershore, Worcester
They are all much the same, the above is better than some because the snail wraps around and brings the airflow down under the incoming air rather that directly into it. Even one of those will work wonders for collecing just and saving your filters and stuff. There is a consideration to be made for the size of the unit, but assuming you just want it on a normal kind of vac or even the record power for small tools, these common 50mm versions will be fine. Naturally don't use one this small on a proper HVLP extractor as you'll choke it.
I need to sort one myself soon.
Plastic tubs will work fine but just need to be reinforced. Lots of people have done it. Do try to stick to a cylindrical container rather than a square one though as it helps the cyclone out.
Essex Barn Workshop
11 Jul 2020
Loughton, Essex
I have something similar to the photo above, and love it. I can't remember when I last cleaned the filter on my vac, and there is virtually nothing in it. Almost everything (99% or so) goes into the barrel.
Big Al
26 Jun 2013
Sheffield
Thanks for the replies guys.
Any info is a help and I will seriously get one ordered.
Just need to find a suitable barrell now.
Gareth62
10 Oct 2021
Rugby
This is what I got this week for my new workshop just finished putting it together today once I know where tools and machines are going I can then decide how the ducting will run
Big Al
26 Jun 2013
Sheffield
Very Nice.
I just wish I had space for the dust drum........
Never mind the other section.
Big Al
26 Jun 2013
Sheffield
Just ordered the same cyclone.
All I have to do now is locate a drum/barrel.
Big Al
26 Jun 2013
Sheffield
Just ordered the same cyclcone from Banggood in China and got a £2.46 discounts so can't be bad.
Would you know the length of the M5 bolts that secure the cyclone to the drum lid?
Many Thanks.
julianf
10 Nov 2017
devon
I have a small cyclone here, connected to a Henry.
Only this week I was using it to suck up wet mud and a little bit of water...
Probably not recommended but it's what I was (successfully) doing all the same...
Sideways
26 Dec 2017
United Kingdom
If you should happen to buy a second one at some point, the black dust commander at about £30 is my recommendation.
It is advertised as a conductive plastic, so antistatic hoses in and out will continue to be antistatic.
I've never used another type, so can only note that mine works well for me and is relatively thick robust plastic that has survived the drum being pulled over numerous times.
Big Al
26 Jun 2013
Sheffield
Thanks for the info.
Just ordered a similar cyclone so I will hope for the best.
Allen Quay
3 Oct 2021
Northumberland, UK
Does the Triton DCA300 Dust Collection Bucket serve the same purpose as a cyclone? Are they both used to reduce the amount of dust that goes directly into a shop vac?
Big Al
26 Jun 2013
Sheffield
Not come across this item as yet but I assume it is just a dust collection system and not actually a cyclone.
Allen Quay
3 Oct 2021
Northumberland, UK
Allen Quay
3 Oct 2021
Northumberland, UK
Just been reading the stickied post about dust extraction in another section of this forum and it sounds like the Triton dust collection bucket is an example of the "bin lid" type of dust separator, so it isn't going to remove fine dust. A cyclone is a much better for option for separating out the fine dust, to stop it reaching the shop vac.
johnnyb
13 Nov 2006
Biddulph staffs
I've got a few cyclones type things. the thein thing I made is great tbh some gets past but the vac drum itself has a sort of angled nozzle making that a sort of cyclones. it's amazing how quickly the sawdust can fill the full sized dustbin when I'm ripping thick stock. that's only on my sawbench and the vac is a 3 motor 3000w affair.
I've just connected an at155 up to the planer, spindle and bandsaw with 100mm clear plastic. very good suction. quite small bin= much changing.. the fine collector doesn't seem to get hardly any dust must be 99% maybe less on the bandsaw. the cyclones adds a high pitch whistle to the setup that's a bit annoying.
Essex Barn Workshop
11 Jul 2020
Loughton, Essex
This is one of the barrels I bought for £15 and use, nice lady too but in North London so probably no good for OP.
I haven't found any need to strengthen the barrel, perhaps its slightly curvaceous shape helps?
Here it is constructed and in my workshop:
Richard_C
17 Oct 2019
Cambridge
I had a small plastic tub from bird food supplies. Maybe 30 cm dia 25 Co deep. Thought I would try it out, cut a ring of ply to strengthen the lid so the fixing bolts have something to work on. Put brick in it to stop it toppling over. Works fine so still using it. Need to empty more often but it is very quick to do. Being small it needed no reinforcement apart from the lid and takes up minimal floor space and was free. No need to over complicate.
