Cutting matching housing/Dado joints at a 30 degree angle
Bluekingfisher
16 Mar 2009
Land o' Burns.
Gents/ladies - I'm working on a small project and have come to a grinding, head scratching halt on this particular aspect.
I have drawn a small sketch but IT issues are preventing me from uploading it, so hopefully I can describe my dilemma without the image?
I am cutting 6mm x 3mm housings in 6mm MDF panels which measure 500 mm x 125 mm to accept 6 mm dividers. I am cutting the housings at an angle of 30 degrees, the idea being to make up a small rack much like a traditional kitchen plate rack, making sense so far?
I need to have the two panels ( which will create the top & bottom panel) so the corresponding housings match up with one another. The spacings between the housings also vary, to accept the items I will fit in the spacings.
I was using a dado cutter at the table saw with the mitre gauge at 30 degrees to cut the first set, then realised I could not identify a means of accurately ensuring the housings of the opposite panel would match up.
Would it be better to make a small jig for the router? How would I ensure accurate spacings on both panels.
My scalp is raw from all the head scratching.
Any assistance would be much appreciated.
David
The way to do this - and to get the angles to match EXACTLY is to use a sine bar. You need a spacer (in your case exactly half the length of your sine bar, as sin30 = 0.5) and a roofing square.
There is stuff on YT about sine bars, or if you have my DVDs then look at WE9.
