I'm in the middle of making a right-angle-triangular table to go in a corner, and as such, I need to have my back two apron rails and stretchers at 45 degrees to the front ones. I'm keeping the front two legs perpendicular to the front of the table, so the two back aprons and stretchers are going to need to be mounted on the square-section legs at 45 degrees.
I know I could cut a 45-degree slice off the back of the leg and then just cut the mortise normally, but I don't like the idea so much. Plus it's cheating! ;-)
I had a practice go on a spare piece with the most-obvious-to-me approach, which was to clamp the workpiece at 45-degrees using a set of blocks to hold it, chisel a flat into the corner to cut the joint into, and then mortise into that flat. Which mostly went well:
Unfortunately, I fell at the last hurdle - while cutting the mortise, I couldn't help but mar the corner at the top. I think I squished it with the back (face? I don't know) of the chisel when I was paring out the waste from the bottom of the hole. I tried leaving some un-trimmed waste at the corner at first, but it became quickly apparent that it'd get in the way of the mortise itself. :/
Anyone got any tips for cutting the mortise out of here without damaging that corner (and without buying a mortiser ;-) ) ? I suspect I could get away with it on this one, since it's just a table to stand some plants on in the hall, but I'd know. There's already some hidden mistakes on this project, and obviously I'd like to learn to do stuff like this more cleanly!
A related question, of course, is: is this kind of joint likely to be a problem with movement over time? The apron will obviously only be enclosed on one side - I'm planning some of those little L-shaped blocks to hold the tabletop on, don't know what they're called - but the stretchers would have the end enclosed on two sides with the triangular section of the leg...
