Quantcast
Curious question
Kevinmcintosh
15 Nov 2020
Northayrshire
I have built a joined bench in my garage 2.7 by1.7 is there a specific height the underbelly should be mines is 9inch from ground seems to be a lot of wasteunderneath
Cabinetman
5 Jan 2017
Caistor lincolnshire
Nobody has ever said it should be a size, but you want to be able to get your toes under- 4-5”? and then that bottom rail is structural so it’s probably 3-4”, then a sheet of ply on top and you aren’t far off 9”. Ian
Rorschach
Living on borrowed time
6 Jan 2016
Devon
Put some storage under there, just allow room for your toes.
t8hants
17 Apr 2010
Isle of Wight
Its a trade off you can either have some storage below the bottom rail, as you have with less room available above, which unless it is fully enclosed just fills with dust and shavings. Or just enough for your toes. Use your 9" for deep storage with items in plastic boxes, about 6" in for toe room.
