wobblycogs
Hi,
I'm currently building a router table and to make life difficult for myself I've decided to use a piece of beech worktop for the table. After delivery of the worktop I unwrapped it and stored it on the workbench for a couple of weeks to acclimatise to the workshop. What I didn't think of at the time was letting air get to the underside of the worktop so it's cupped (warped perpendicular to the grain direction) as the exposed face has dried faster, the middle is about 5mm low compared edges. By clamping the worktop to my (very sturdy) router table cabinet I can get essentially all the cupping out of it.
Do you think if I leave it clamped down flat for a week it'll give up the fight and stay flat? Clamped to the cabinet there's good air flow to the top and bottom so (fingers crossed) the moisture levels will even out. I'll also be screwing it down tight (while allowing for expansion) in the final fitting. I could also easily fit four pieces of 50x50mm angle iron across most of the depth if necessary. Kerf cutting the underside is a possibility but I'd like to try and avoid that if I can.
Any other ideas? Advice on a finish would be appreciated too, I had planned on just leaving it bare but perhaps that's not such a great idea.
Cheers :-D
Cheers :-D
