My garage consumer unit has a crimp on the end of the pre-fitted N.
Do I need to crimp the ends of my 10mm SWA before inserting into terminals, or is it acceptable to just insert them as they are?
I also need to run an earth from the steel wires of the SWA. This will need to be crimped in order to attach to the SWA gland washer. Is it acceptable to use a small length of the cable from inside the SWA for this purpose?
