Bodgers
I'm about to start prototyping a desk.
The top part of the desk is a 200x500x1100mm carcass.
The ends of the carcass I want curved.
It is too high to cut the curve by resawing on the handsaw (500mm).
The outside of the curve I will probably shape with a hand plane and maybe a spokeshave with then some low grit sanding etc.
The inside curves might be tricky. I had thought about some sort of cove cutting setup on the table saw, but don't fancy the safety trade offs with that. I could use a power router and then somehow smooth it out...
Any ideas?
Sent from my Redmi Note 5 using Tapatalk
Any ideas?
