Glynne
A few weeks ago I bought a Corner Lock Jointer Bit from Wealden Tools: -
http://www.wealdentool.com/acatalog/Online_Catalogue_Corner_Lock_Jointer_890.html
As I do box making, I thought that for veneered boxes I could cut down on the construction of the base carcass (MDF / Ply) and hence bought the cutter as I've always been impressed by both the products and service from Wealdens. So today I thought I'd have a play and checked the product details (as above) and watched the video of the cutter in use.
http://www.youtube.com/watch?v=5QmzxKbfguY&feature=youtu.be
However, I struggled to recreate the joint shown in both the diagram and video and ended up with a very shallow mortise and tenon joint. Coloured in for the photo.
I couldn't work out how you could possibly recreate that joint unless your stock was exactly 8mm thick - which mine wasn't.
So back to Wealdens video firstly then and Ron's Tips to find he was using a different cutter to mine and, whilst it's nice to watch him, it wasn't a lot of use.
A quick Google revealed the type of joint I had envisaged when I bought the cutter so back to the router table with some 12mm MDF.
After a couple of miserable failures, the pen and paper came out and with a scale drawing, all was revealed!
Once you are set up, you can rout both the sides and the front and back without any adjustment of the fence or the height of the cutter - you simply rout one vertically against the fence and the other flat on the table. In both cases the inside face on your box parts being against the fence & table. Simples! (after you've spent a couple of hours working it out).
I then decided to test my calculations (i.e. be a smart ars*) and see if I could leave a deliberate shortfall in both sides so as I could add contrasting edging / stringing and it worked. You can just about see some scrap square stock at the bottom of the joint as an example.
The secret (or bleedin obvious to anyone apart from me) is that the vertical pieces are positioned so as to create the 4mm groove exactly 4mm from the bottom to fit in with the cutter dimensions. As long as your depth (i.e. the fence) is > 4mm, it creates uneven sides above and below the groove which is what you want. You then rout the other pieces flat on the table and the longer "tenon" simply passes over the top of the cutter. You can easily work out the depth of cut by taking 1/2 width of your board and adding 2mm.
It is probably easier to draw that explanation so if anyone is interested, please let me know and I'll knock something up.
If you use solid wood, you will get some end grain showing unless you go for the stringing option but the other benefit is that you can use the set up to rout grooves for your top and bottom without any other adjustment.
So I still didn't make anything, but at least I know how to use another cutter!
