Cheshirechappie
We frequently have discussions about minimising tearout by setting up Bailey-type smoothing planes to deal with it. Perfectly valid approach, of course, but there are other strategies.
Stock selection - for components like drawer sides and runners, choose milder, straight-grained stock if you can. Such components often have to be finished accurate to a dimension or fit; bringing a drawer side to a nice fit in it's apperture but then having to take more off to remove tearout would be irritating to put it mildly.
Hiding it away - on the undersides of table-tops and insides of cabinets, don't worry about it if it's out of sight. Maybe not an appropriate strategy for a really fine quality piece, but a pragmatic approach for reasonable quality 'normal service' pieces.
Scrapers - the humble card scraper or scraper plane were invented for just this sort of job. Use the plane to get things as good as you can, and take out the rest with a scraping session. You do need to be careful to avoid working on too concentrated an area and forming hollows, though.
Sandpaper - some people regard it as cheating, but if it works why eschew it? On flat surfaces, use a cork sanding block and 100 grit to remove the worst, then work through 220 grit and 320 grit for a surface suitable for finishing. If the tearout is really bad, it may need power sanding to avoid a long session of rubbing, and (as with scraping) care has to taken to avoid forming hollows.
Infill planes - for those lucky enough to possess one (or more!) this is where these planes excell. Just don't expect them to cope with heavy stock removal.
Any comments and additions?
