Considering a Budget PT
Petey83
19 Mar 2014
Enfield
So since getting back into woodworking I've been managing using a mixture of hand planes and power tools (router, router table and table saw) to dimension and thickness timber but I've hit a few limitations.
Firstly thicknessing by hand is no fun and is going to be less fun as I try and size up the timber I'm working with now I have a good source.
Secondly I want to get into bandsaw boxes now I have a decent bandsaw and it seems like flat faces is key to this given the blanks are made by laminating boards.
I was thinking about just getting a lunch box thicknesser and using a jig for flatening faces but that looks a bit fiddly.
So I'm now considering a cheap P/T that can be store away when not in use.
The Metabo HC260 looks decent for what it is but is probably more than I want to spend given the recent bandsaw outlay.
Then there is this from Lumberjack https://www.lumberjacktools.co.uk/produ ... r-lum00206
It's a clone of the generic cheaper P/Ts but it at least has cast iron tables and a reasonable looking fence. Noisy brushed motor but that just is what it is I guess.
I've thought about some of the even cheaper clones of this machine but having had the Titan from Screwfix before I decide cast iron tables and a box type fence are a must at a minimum.
Any other budget suggestions I should be looking at?
sammy.se
3 Aug 2014
London
The erbauer Screwfix one seems cheap and cheerful. Not amazing, but does a half decent job.
Peter Millard reviews it on one of his videos if I recall.
Sent from my SM-G973F using Tapatalk
RichardG
If at first you don’t succeed have a cup of tea.
29 Mar 2018
South Norfolk
Unfortunately I believe that one is end of line now, we’ll that’s what my local screwfix said a few months back.
Richard
Petey83
19 Mar 2014
Enfield
Fits the bill, just a case of if Screwfix ever have them back in stock - seems they've still got the limited essential stock measures in place
MJP
8 Apr 2017
Swansea
If the OP does go for the Lumberjack P/T I'd be very interested in his opinion since I'm thinking of buying the same model.
Martin.
