Confused !!!
Mdotflorida
7 Nov 2003
South Wales
Just received my new machines. Jet supersaw, 18" bandsaw and dust extractor. :lol:
The tech specs in the manuals are confusing me. They say Installation fuse protection 16A but all machines are fitted with a standard 3 pin pug and 13A fuses !!!.
Has anyone got these (or similar spec'ed) machines and are using them happily on a standard 30A ring ?
I had thought they would arrive with 16A plugs on, so wired 3 x 16A circuits each with its own MCB in readiness.
Would it be better to chop the plug off and fit 16A types ? :?
johnelliott
16 Apr 2003
Near Swindon, Wiltshire
All my machines run on 13amp plugs. The only one that blows a fuse now and then is the Electra Bekum PKF255 saw, and that only when the blade is jammed by bits that have dropped down the slot.
Noel
Moderator
Staff member
Moderator
7 Aug 2003
John,
Time you made a zero clearance insert which will support the timber being cut and stop off-cuts falling down.
T/S, B/S, Jointer etc all run on 13A plugs. No problems other than the odd dimming of lights on start up.
Rgds
Noel
Adam
10 Sep 2003
UK
My TS is rated at a 20amp supply, I run it off a 13amp plug no problems.
Adam
Aragorn
6 Feb 2004
East Sussex
My Jet planer requires a 16amp fuse. It was supplied with what looked like a continental plug (but what do I know!). I easily found an adaptor to plug it into the socket which is protected by an RCD. The 13amp fuse in the adaptor blows ever time, so I wrapped 16amp fuse wire around the terminals in the adaptor in place of its 13amp fuse.
This is probably dangerous (I've no idea - it works fine) so hopefully others will advise whether you could just do this like me.
My TS and dust extractor both blow 13amp fuses so I had these hardwired - never any problems. Maybe you could do this instead?
Adam
10 Sep 2003
UK
I think, err, you may have hit the nail on the head there. I measured the currrent consumption both running and at switch on, before I decided to use a conventional plug. The "continental" plug, is actually probably not continental, but a special high-current plug. Was it like this:
Thats a 15 amp 3 pin pug, as opposed to the square types which are only 13amp?
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi Aragorn
The jointer that you have requires a 16A connection.
The supersaw just makes it into a 13A connection, however the 16A is recommended.
My personal advice fwiw would be to switch off the equipment immediately and call an electrician. I should qualify this by saying that I know nothing about electricity.
Neil
Aragorn
6 Feb 2004
East Sussex
Hmmmm.......
I was expecting a firm slap on the wrist!
Adam, that's not the socket, but thanks for taking the trouble. It's a two pin socket, each pin a good inch long and around 4 or 5 mm thick. My local hardware store sold me a standard travel adaptor that it happily fits into.
So is what I'm doing very dangerous? Should I be getting an electrician along tomorrow?
Noel
Moderator
Staff member
Moderator
7 Aug 2003
Adam, Aragorn,
This is the plug that comes with most Jet equipment
The plug is the normal French/Spanish/Swiss etc item as the Jets are mostly shipped via the Jet parent company WMH in Switzerland.
The plug has 10-16 printed on it and I assume this to be the amp range. The adaptor is only 13A and all works well.
Aragorn, hope your dealer didn't charge you for the adaptor.....
Rgds
Noel
If you canny see the images, do a URL
johnelliott
16 Apr 2003
Noely":3j2wwqkp said:
John,
Not possible on the EB PKF255 I'm afraid, due to the sliding table which comes right up to the side of the blade
Alf
22 Oct 2003
Up the proverbial creek
Urgh. What is it with youse guys and images?! Even having put the code right they still don't want to show. :roll: I can only point out that this never touch-wood-where's-my-four-leaf-clover? happens with Uploadit... (Hint hint (hammer) )
Cheers, Alf
Noel
Moderator
Staff member
Moderator
7 Aug 2003
Alf,
I would quite happily use uploadit but can't reduce image size to suit their file size limit without using software I don't have. So I'll send the images to you and you can post them, please.
Rgds
Noel
Noel
Moderator
Staff member
Moderator
7 Aug 2003
Thanks Chris,
Looks interesting although I noticed in the "what is" section -"easy to use for beginners" etc, put me off a bit...........
Thanks, again
Rgds
Noel
Mdotflorida
7 Nov 2003
South Wales
Thanks guys
Once again a plethora of information. :D
My understanding then is that my machines will probably be ok on a normal ring but it would do no harm to plug each of them in to their own 16A MCB protected supply being as I've already installed them. :)
Aragorn
6 Feb 2004
East Sussex
Yep - sorry Mdotflorida - kinda hijacked you thread there!
Sounds like what you've written is going to be fine.
Alf
22 Oct 2003
Okay, now I'm confused. I just uploaded the images as you sent them and there was no trouble at all :? Where does it give the file size limit, 'cos I couldn't find it? Anyway, here they are to prove it (I hope...):
But not for long 'cos I don't have a paid account and I've got some Porch related stuff that I'll be getting round to posting soon, and I'll probably need the space.
Cheers, Alf
P.S. Sorry MDF, just having a private conflab in your thread :oops:
Noel
Moderator
Staff member
Moderator
7 Aug 2003
Alf,
That's because I mailed them to you and OE gives you the option to reduce. Will try Chris's suggestion.
Rgds
Noel
PS Is your Porch a 911 or a Boxster?
Alf
22 Oct 2003
Ah ha! In that case, you could mail them to yourself! :idea: :D
Cheers, Alf
P.S. It's a galoot special, designed for drive-bys :wink:
