matt
Hi All,
Long time no posting - so much to do, so little time! Anyhow, I'm hoping for a quick sense-check on the following before I go spend more than I need to, and end up with more than I need!
I have to build an extension to an existing shed base tomorrow. The size (of the new bit) is 3ft x 10ft.
I've used an online calculator to estimate the volume of cement, sand, and gravel I need; however, I'm slightly sceptical about the numbers and would be grateful for an experienced view on whether the volumes looked broadly correct.
This is what it calculated:
Cement 134kgs (6 x 25kg bags)
Sharp Sand 252kgs (10 x 25kg bags)
Gravel 504kgs (20 x 25kg 20 bags)
Also, am I correct in saying I can substitute the gravel and sand for 30 bags of ballast?
Thanks in advance.
Matt
Thanks in advance.
Matt
