engineer one
hi there well along with the new year resolutions, and the beginning tidy up, i want to make a new computer desk which helps me with the design work for some modelling work that i do.
i use a cad programme, but work from full size old fashioned blueprints
up to A0 size. i was thinking about a modified pedestal desk, but on top i want to put a kind of light box.
i know like them all, it might be pie in the sky, but at least if i get the data,
then who knows it might actually get built.
i think what i want is two transparent layers with a small gap between each, in to which i can slide the drawings, and beneath which is a light source. so part of the question is what to use as a light source, because we do not want too much heat in use, and secondly, the size of the light box to get rigidity over about 36x48 with a depth of say 4 to 6 inches.
Should i use glass or poly carb for the top either one or both pieces.
obviously the wooden supports will have air holes in them, should we have a fan to draw air over them?
the rest of the desk should be one pedestal with two file drawers, and the other will be for the cpu box, plus space for the printer, scanner et al.
below the light box will be a couple of drawers to take excess drawings, this should be about 6-8 inches deep. so i guess it will end up about 42 inches high, and maybe i will use a tall chair like a real draughtsman.
anyway, how about it, any bright ideas particularly about the light box??
what wood, etc.
all the best for the New Year.
paul :wink:
what wood, etc.
paul :wink:
