transatlantic
Boom!
I'm making a jig where I have an M8 bolt that is used as a micro adjuster to raise and lower a corner of table (there are actually 4, one for each corner of the square table). It works great, but the bolt can rotate with vibration, and is insecure.
I'm wanting to use a very strong compression type spring to hold the adjustment in place and allow for easier fine tuning without having to secure a second nut (which is fiddly and often adjusts things slightly)
Does anyone have a link to a suitable spring I would used for this? as mentioned, I want it to be really strong so that you have to use a bit of force to compress it., and so should hold the adjustment securely.
I've had a look on ebay, and they seem to be extremely pricey, around £3-4 each! .. so am hoping someone can point me to something a little cheaper that will do the job.
I figure there must be hardware kits like below made for the purpose.
Also, I am guessing I can't use loctite for this task?
Oh and I can't use a blue lock nut on the receiving end as the receiving end is a threaded insert
