I need to get compressed air from one side of the bungalow to the other. My sensible head says do it properly in hard pipe and have done, but it would be much easier to run a hose through the loft and down into the 'shop. Is there any difference in pressure loss over a distance between the two? I would like to be able to switch it off remotely as well - could I use a switch with a relay to save a fairly large cable/flex running all (50') the way over? Other suggestions?
