Chris Knight
OK, I'll stick my neck out - here is the start of my entry!
Sticking to the rule that it must include a technique not previously used, I have elected to try using secret mitred dovetails. I decided a bit of practice would not go amiss so:-
I found it easier to cut the waste in the centre so that whilst chopping out the waste, it was not then wider than the entry to the socket for the tails.
Checking the depth of the sockets having pared to the "back wall"
Completed set
Dry fitting - unglued.
My plan is to make a box for my newly acquired carving chisels. I aim to make it in ash and use some of the ebony left over from the chair, for accents here and there. It will be about 13 inches on all sides and will house six drawers for chisels and slipstones etc. I would like to carve something on it but as my skills are still negligible in this arena, I am planning to make a couple of removable panels tthat I can carve on and replace when I get a bit better. In this sense the box will never really be finished.
Cutting the D/Ts isn't very easy I have to admit. I am rather daunted too by the number to be cut! If they are too messy, I may just go to the Woodrat and rely on some other aspect of the box to fulfil the novelty criterion.
By the way - a carver's skew chisel is great for cleaning up dovetails - better than the regular skews that I have ground myself from ordinary chisels as it can simply turned through 180 degrees to cut the other way - can't think why this did not occur to me before - that is an unexpected benefit of the course!
Completed set
