Quantcast
Combination or separates
julesbike
4 Dec 2020
France
Hi my winter project is to reclaim my garage and create a proper workshop. My wife is now the proud owner of a 15 sqm garden office I built using Douglas fir, so now it's my turn!
I have a 7m X 5m space with 2 sectional up and over doors. I need to store some bikes and garden tools so one of the 5m walls will have big cupboards for those. Otherwise I'll have about 15m of wall space and a large open space in the middle.
Currently tools are mostly festool hand tools with an MFT table. I'd like to move to buying rough timber and building furniture and cupboards.
Ive been lusting over multi function machines like the hammer C3 31. But would I be better buying separate items? The hammer looks like something that you put in the middle of the room and it never moves. I assume with smaller individual machines you can wheel them around depending on what you are working on.
Interested in your thoughts.
I'll post process in the workshop forum once I get going. Slow and steady. The cabin took 1 year.
Doug B
Shy Tot
6 Aug 2008
@dougsworkshop
my workshops not huge so I went for a compromise rather than a full combi or all separates, I went for a planer/thicknesser & a saw/spindle moulder both machines are on mobile bases so I can move them to the wall when not in use to free up space, I’ve been very happy with how they’ve worked out.
julesbike
4 Dec 2020
France
yes I was thinking the same plus a band saw and chop saw. I was just looking at the felder site and it looks like their smallest table saw has a spindle. I have used a friend's workshop and he has separates.. the only concern is the planer thicknesser seems that swapping between the 2 involves lowering the table each time for the dust extraction. Is this a pain or do you just learn to work in batches.
clogs
just can't decide
24 Jul 2020
Vamos, Crete, GREECE.......
combination machine are always a comprimise......
this is mine, all 2 tons of it.....and obviously 3phase.....
it all depends on the room u have......
I prefer seperate machines but again u need a lot of extra room......
dont know about the Hammer model u mentioned but a lot have limited motors, even the not so cheapies need belts swopping.....
prefer 1 motor per mode but some have the spindle running at the same time as the planer.....[the spindle shaft can be lowered under the surface of the machine and has security cover....
also, some to change from a jointer/planner to thicknesser mode u have to flip tables....another pain....
you really need to find the machine u want then use it in all modes before u buy.......dont be in a rush.....
Doug B
Shy Tot
6 Aug 2008
@dougsworkshop
Whilst swapping from planing to thicknessing does take a minute or so for me as I usually need to move the machines towards the centre of the workshop to Maximise space it took longer when I had separates moving machines than it does swapping functions on the P/T, for me it was all about maximising space.
I don’t know if Felder/Hammer have a showroom near you but it’s really worth going & seeing their machines, I have their small Hammer saw /spindle, it’s fairly basic but has done everything I’ve asked of it over the last 3 years.
julesbike
4 Dec 2020
France
it all depends on the room u have......View attachment 97739
that is a beast! I think the transporter would have a heart attack trying to get that up my drive 😂. the hammer has individual motors afaik. yes I'll definitely visit a dealer first.
julesbike
4 Dec 2020
France
yes that makes sense moving machines always takes time. talking of which, what hammer model is it? how easy is it to move around.
Mrs C
3 Jan 2016
United kingdom
Separates if you have got the space.
If you have to go combi have a look at how much of one tool you have to move use another. I think that the real pain would be setting your spindle, changing to the saw only to find you need to run another piece through the spindle but have lost the setting.
I think that Felder do a quick change spindle head which I am assuming goes back in set to the same height that it came out of. This might make life better.
Swapping between top and bottom on a p/t is ok. I like being able to see what is being fed into the thicknesser which the lifting tables allow, this isn’t so easy on a fixed table machine.
Yojevol
Clocking on
29 Jan 2017
Cheltenham
Yes I do, or rather did, find it a pain, so much so I've now abandoned the thicknesser on my Felder and replaced it with a stand alone thicknesser. It's a 12" Record which is good for 99.9% of my work. For the other 0.1% I have to resort to the 14" Felder. I bought the machine new but I always regret not splashing out for the mechanised thicknesser platen rise and fall optional extra. It would have been a better investment than the extra 2" on the planer width.
Brian
Mike Jordan
21 Apr 2016
Derby
An under and over planer thicknesser without lift up tables is my choice. British cast iron will outlast any Chinese rubbish and give a lifetime of service. My Sedgewick MB has done 45 years and cost me one drive belt. Yes they are expensive but you get what you pay for. AIl my machines are separate on the grounds that combination machines are a collection of compromises, usually access to all four sides is required so it takes up more room than you may expect. My total contribution to the Far Eastern economy are a band saw and lathe, both of which have a British label stuck on. Two professional users of my acquaintance have worn out Chinese machines and been forced to buy replacements, opinions may be changing regarding these machines and the supposed value they offer. Second hand machines can be good buys providing they haven't been "reconditioned" with just a spray gun.
A
Derek Cohen (Perth Oz)
2 Mar 2005
Perth, Australia
I have had a Hammer A3-31 jointer/thicknesser for about 7 or 8 years. Spiral head. 305mm wide. My workshop is half of a double garage, so space is a factor. I love this machine for its superior performance in a reasonably affordable package, and one that simply requires that you do need to plan your work order. Separates benefit space and one disinclined to be organised :) I do not miss the separates I had before.
The tablesaw is a separate machine. In my case, a short stroke Hammer K3 with 1250 slider.
Regards from Perth
Derek
julesbike
4 Dec 2020
France
Regards from Perth
Derek
thanks Derek nice to see how you have made everything mobile. There is something satisfactory about having a single brand. I've tried to stick with festool and have mostly regretted when I deviated. I agree with Jordan about quality so I'm hoping hammer are the equivalent of festool for larger machines.
Is the table saw mobile too? In the hammer promo videos they show the handle that allows you to pivot the table but I've only seen people moving it a forward and backwards a small amount.
thanks
2 Mar 2005
Perth, Australia
Hi Jules
The Hammer K3 is a fantastic slider. Yes, it is on wheels, although I am not sure you would want to push it around. Heavy. Here is an older photo ...
You could say that mine is a combo machine as I have built a router table onto the outfeed side ...
Both the tablesaw rip fence and the router table fence (which I made) use JessEm guides (brilliant!) ...
This is a very tricked out set up. If you know a little about me, I modify everything! :)
I have added a Power Tool and Machinery section to my website, which has focussed on hand tools for 20 years. There will be many (a lot!) of power tool mods and tune ups posted there, along with joinery, etc.
Regards from Perth
Derek
Illy
12 Feb 2019
Blackburn
Slightly off topic but the first thing I did in my garage was to change to side hinged doors instead of up and over. This enabled me to install a sill with better weatherproofing and put insulation board on the inside of the doors. The result was a comfortable temperature throughout the winter - a massive improvement.
I do note the original poster is from France though, so the climate will be different from Northern England !!
julesbike
4 Dec 2020
France
Yes the sliding doors are well insulated and I live in the south of France so heat is more a problem 😅. But the annoyance with up and over is that the roof space is unusable. Cost a fortune with motors etc..so will have to live with.
julesbike
4 Dec 2020
France
Hi Jules
Regards from Perth
Derek
thanks Derek your website is very useful I'll have a good read 👍
Doug B
Shy Tot
6 Aug 2008
@dougsworkshop
The P/T is an A3-41 the saw/spindle a B3 both of which I made mobile bases for as the factory fit option is one directional so didn’t give the ease of movement I wanted.
beech1948
16 Aug 2004
Crowthorne, Berkshire
Ask Felder. Seriously.
My combo a Felder BF required a 5mx5m space around it. Thats to be able to operate it with timber infeeds and outfeeds. So your 7mx5m space will only have a free 2mx5m space at the back.
If you have the space then combos are fine and dandy. If you are tight on space you will regret it for ever.
julesbike
4 Dec 2020
France
yes I think I've pretty much concluded a mobile setup of separates will be the way forward. I'm a bit disappointed that the hammer table saw does not have a better solution for moving around.
