disco_monkey79
- Joined
- 5 Oct 2009
- Messages
- 671
- Reaction score
- 41
Hi
Any plumbers on here? I recently moved in to a new place with a combi boiler.
I'm decorating, which will entail removing radiators in order to decorate behind them.
Someone has suggested that I can remove one or 2 rads, and temporarily cap off the pipes, which will enable me to re-pressurise the system and continue to use the boiler (which would be good as it's the source of the hot water for washing etc), and heat the rest of the house.
Is this correct? Can the system still work with one (or more ) radiators capped off? Surely that stops water from flowing throughout the system? Or does the water flow from the boiler to each rad separately, rather than on one big loop?
Beyond changing tap washers, plumbing is entirely new territory, so apologies if this is an silly person question.
