Clifton cap iron - not good enough?
Harlequin
20 Sep 2008
Leeds
Thought I would try the clifton 2 piece cap iron (heard so much about cliftons in general)
So got one from Axminster
Found that the removable piece had a few burrs on the edge - sorted that out but still found that the piece rocked side to side
2nd pic shows me pinching one edge to reveal the gap appearing on the other
well - heres the culprit, significant burr on the centre hole, the piece pivots on the burr
The whole thing reminds me of this review by Mr Schwarz http://www.wkfinetools.com/contrib/cSch ... ifton2.asp
Clico need to sharpen up a bit if they are to play in the premier league -attention to detail is everything at these prices and I don't think it unreasonable to require it as a pre-requisite
One could argue that the locating pin pivot point, has some advantage. A three point support is automatically stable, so the front edge of C/B should sit flat on blade?
David Charlesworth
Having recently brought one of these from Classic Hand Tools I noticed something similar. The rocking didn't seem as exaggerated as yours seems to be and I thought about taking some tools to it to sort it out, but I wanted to try out my recently fettled Jointer.
When the lever cap is tensioned it still forces the cap iron down flat across the entire plane iron. I used it for a good hour and had no shavings/chips that managed to force themselves underneath, in fact it works perfectly. I think DC is right that the three point rest does not matter once an even load is administered from the lever cap.
If one had a 4-6mm thick plane blade with a hole/slot for the
yoke, would it be possible to use it without a chipbreaker?
I think a chip breaker is not needed if the blade is thick enough
to resist bending. Also I have noticed that the chip breaker bends
the plane blade very obviously. The middle of the plane blade does
not touch the frog this way.
Ali
Hi Ali. That's why the 2-piece cap-irons (Clifton or Record) are good - they don't apply bending forces to the iron.
That should work BUT, you'd want a series of slots, otherwise after 5-10mm of wear you could no long extend the iron through the plane mouth.
Cheers, Vann.
Cheers, Vann.
Hi Vann, I bought the Clifton cap iron with that idea of it not bending
the iron. Unfortunately it actually does bend the iron. When I put the plane
iron without a cap iron on the frog, it sits very flat and I can't see any light
coming through, but even the clifton cap iron causes it too bend. Let me
try again and report back.
Take care,
Ali
jimi43":ii8illf9 said:
woodbloke":ii8illf9 said:
Silence is golden :-" :lol: - Rob
Only broken by the occasional scream of "OUCH MY TOE!!!"
:mrgreen:
Jim
Or "Dammit, I can't reach that far back under my bench!"
I have had mine a few weeks, only dropped it once.
woodbloke":3h5l77cu said:
jimi43":3h5l77cu said:
James C":3h5l77cu said:
.............I have had mine a few weeks, only dropped it once.
I'd send it back. It's not performing as it should. :mrgreen: :mrgreen:
Jim
It is Jim...it dropped off! :mrgreen: (hammer) - Rob
Amazing skill....it is unusual for a trainee of the Clifton iron to achieve such a high level of double retention in just a few days.
I though I was an expert....after all...I did train a whole pack of bench dogs in three months...and with the Record planes I have......... a quick, stern, "STAY"....is enough!!!
Remarkable!
:mrgreen: :mrgreen: :mrgreen:
Jim
David Charlesworth
Hence the fact that Milking stools only ever had three legs! :wink:
