Clear Finish for exterior use
machone
23 Apr 2012
Alkmaar, Netherlands
I have made a couple of horse name boards from a piece of American white oak. I’ve sanded them and really like the colour. However, I have used yacht varnish before and this gives a yellow finish making it look a bit like pine.
Any recommendations for rough use finish that will keep the nice Gandalf the grey colour?
thanks
machone
23 Apr 2012
Any other suggestions? I have just used oil & varnish on this one but it looks very different & I still like the light colour pre-treatment.
sometimewoodworker
4 Dec 2008
Watford, Non S-At, Udon Thailand
thanks
Virtually the only finishes that don’t give a yellow tone are water based ones, so that’s what you need to look for
Cabinetman
5 Jan 2017
lincolnshire Wolds
But the water-based ones won’t stand up to outdoor treatment, I don’t think you will find what you are looking for I’m sorry to say. Cuprinol type finishes are likely to last longest but probably not the look you wanted.
machone
23 Apr 2012
Ok, thanks. Went for Danish oil then epiphanes gloss in the end. Very different look but should hold up. Still interested in finding a finish that preserves the ‘unfinished’ looks and colour of white oak. Will look for water based and do some experiments.
TheTiddles
14 Oct 2007
Wiltshire
I think you’re chasing your tail here.
Unfinished oak will look like unfinished oak, go grey and probably last a long time.
Finished oak will look like finished oak, eventually go grey and probably last a long time.
What look are you actually after?
Aidan
Woody2Shoes
Impressive Member
5 Jan 2015
Sussex UK
thanks
A water based finish should minimise yellow discolouration. But as already said, won't be longlasting. Why not just save effort and let the timber weather naturally?
sometimewoodworker
4 Dec 2008
Why should a water based exterior polyurethane not last a similar time to an oil based exterior polyurethane? A spar varnish like Epifanes is in a different category sure and will probably last longer but all exterior finishes have a shorter life and need renewal quite often (every year or five depending on the strength of sun exposure and film thickness).
machone
23 Apr 2012
This is the look/colour I am after but if I leave it outside it will look like that for about a week, whereas with varnish it looks very different but with a few coats will stay like that for years, after a wipe down with a wet cloth!
Droogs
Is that chisel shar ... Ow
14 Mar 2013
Edinburgh
Believe it or not but a spray can of Halfords car laquer is what you are after. It has lots of UV filtering to help prevent colour fade on a car and if you give it just a coule of light feather coats the board wont be too glossy
Cabinetman
5 Jan 2017
lincolnshire Wolds
Well that’s wonderful if it’s going to work Droogs, will it stand up to outdoors weather?
baldkev
29 Apr 2020
devon
Plus 1 for droogs suggestion, but also, osmo do white tinted oils which limit the yellowing. The more ciats you build up, the whiter it'll get, but 2 or 3 usually works well. They do samples for 3 quid, a little pouch of the oil to test
baldkev
29 Apr 2020
devon
I would think a plasticote laquer would be slightly flexible, but even sadolin exterior clearcoat cracks after a couple of years
Droogs
14 Mar 2013
Edinburgh
Yes but my car isn’t made of wood, will it stand the movement slight though it will be?
yes it will fine. I have done a fair few things for outside and never had a problem. you will be very surprised at how much the panels on a car will expand and contract just in the course of a hot summers day with no effect on the paint coatings
