Chuck advice please!
jrussill
New member
3 Oct 2016
Penarth
Hi all,
I'm new here, and new to woodturning. I recently bought a Record Power DML 24x and it came with a chuck as shown in the photo. Does anyone know what make this is? The steel ring is well jammed but I assume that, if I can free it, the screw chuck will come out so it can work as a jaw chuck. Is that right..?
Thanks for any help!
Jon
    81.4 KB
Thanks Paul. Yes, it does seem to be on some second hand Record lathes that are for sale but I can't find any info on it. Guess it's obsolete now!
Jon
It's not a bad chuck, but perhaps a little fiddly compared to a scroll one. There should be a hole in the narrow part you are holding. You loosed off the knurled ring by having a rod in each hole and turning....anti-clockwise I think...
To remove the screw chuck from the main body you'll need to use the C spanner and a metal rod (hopefully these were also supplied). It'll also be a lot easier if you attach the chuck to the lathe.
Dave
