I have been using Proxon blades on my scroll saw because it´s what I can get locally. 99% of my work are puzzles of 20mm (3/4") thickness. No. 3 and 5 are my sizes to go for. I usually cut one at the time, but when I go for quantity, I do stacked cutting.
I got a Pegas starter blade pack with my scroll saw but I used them too soon to be able to distinguish how different each blade cuts.
I was lucky to find the pack (in my messy garage) with only 3 blades in it. It was modified geometry no. 3. I instantly put it in my scroll saw and the puzzles I made with it were the smoothest and cleanest pieces I have ever made. It was like cutting through butter. It even lasted at least twice as long as the Prxxon blades. I was sold on it and wanted to get dozens of them.
Later ,"time for stacked cutting". I put two 20mm pieces of beech wood together. Made my first cuts and snapped the blade. I thought the one was too dull from previous cutting. I put in a new one and it broke within a minute. The same happened with the last one.
Any suggestions? Is the blade not suitable for such thickness? Or is beech wood that much harder than maple or oak? (Woods I´ve never had troubles doing stacked cutting with).
Also, even after making a straight line I was not able to pull the wood back due to wood dust building up behind the blade. After I finish a cut, the built up dust is so hard and stuck that the only way to remove it from a work piece is with a hoover or even and sand it off. Having dust collection attached or not made no difference. It has never been that bad with Proxxon blades. Why is that?
