Choice of timber
GrahamIreland
4 Jun 2015
Nottingham
Hi guys, was looking for some input on a good choice of timber for outdoors, seating, decking and trim on my steel boat. I had chosen southern yellow timber for this, but have discovered over time it has gone an awful nutty brown colour. I had one coat of Osmo uv protection on it.
Anyway, would like something in the mild yellow range like an ash, would this hold up outdoors?
Graham
Osmo UV specifically says in its Data Sheet that it isn't for horizontal surfaces. It really was the wrong finish for those tasks.
No, ash is no use for those jobs either. I can't think of a pale timber that would be suitable, frankly.
I don't know of a light coloured timber for this job but will happily second the nomination of Iroko.
Yes the teak timbers would weather well I'm sure, but these are part functional part decorative, so a mild timber would go better with the paintwork. I'm also curious to try out different timbers, so I ordered a sample of Siberian Larch from EBay..
But I thought ash would be quite strong, don't they make tools and table tops with it?
i would suggest any of the following if you can get them:
Opepe - Nauclea diderrichii - used in sea defenses
Afzelia - Afzelia quanzensis
Umbila - Pterocarpus angolensis
Larch is used for a lot of outdoor applications and will probably serve you well. Ash is incredibly strong but prone to rot and insect attack.
Have a look also at oak, iroko, douglas fir and western red cedar.
Larch, douglas fir, red cedar and iroko are very common so should be reasonably priced.
Cedar is most definitely not suitable for seating if it isn't supported fully along its length. It is a soft, soft timber, and not terribly strong. I'd say this rules it out of contention as a deck material, too.
I've always been happy with Sikkens products for outdoor protection....easy to apply and not dif to recoat after a year or two....the product I used was more oily than plasticky n def not varnish....soaks in well.....
what about Parana PIne.....think they used to make masts out of it...????
As soon as the word boat is mentioned I think Iroko and a few coats of marine varnish.
Has anyone ever experienced the discolouration I saw with the southern yellow pine. Starts out lovely, but within a summer it tarnished to brown. As I said I only did one coat of Osmo uv oil. Didn't expect it to turn so much..
Practically every softwood turns brown/orange in UV light. Light-coloured woods tend to go darker with time, dark-coloured woods tend to go lighter.
