Chess
motownmartin
10 May 2007
Enderby, Leicester
I make some chess boards and stonecast chess sets such as pic
What I want to do is make a box for the pieces, not a problem with making a box but how do I place the seperate pieces so they are seperated and be protected when moved from place to place, any ideas.
I have a couple of ideas but maybe one of you has a better idea or has had a similar experience.
TIA
The bronze / aluminium chess set I just put with my chess / backgammon table came in a box (which I don't need anymore and you are welcome to although as you can see the baize is a bit tatty). It just has holes bored out with Forster bits etc - and that kept the pieces very well
Mark
Mark, this is something like I had in mind, but to make the holes different depths so the pieces are level near to the top of the box so nothing can fall out when in transit, there is a lot of drilling though and the box will be very heavy, just wondered if anyone had any different ideas.
the base wouldn't need to be solid you could use suspended layers ,still a bit of drilling ,this way would also help keep the weight down.
