pswallace
Hi folks, I recently bought two Stanley planes at greatly reduced prices in B&Q,one was A block plane at £10 reduced from £40 the other was the handyman style bench plane ..£6 from £25. I flattened the bottom of both planes using A long strip of 6mm glass bonded to 18mm MDF with 80 grit-120 then 240 glass paper stuck to the glass with Pritt stick...this produced great results. I then reground the irons on the Tormek at 25 degrees then honed A micro bevel with 40-30 then 5 micron lapping paper, again great results .When I tried the block plane on 19mm pine,then 22mm oak I couldn't believe the results,nice cigarette paper thin curly shavings but when I tried the bench plane it just about shaved A few slips of the pine and it just juddered along the top of the oak. I wasn't expecting 'Veritas' or 'Lee valley' type results but after getting such great results from the block plane I thought I could get Ok results from the bench plane but no matter how much I adjusted the set up I just couldn't get acceptable results. Can anyone tell me where I'm going wrong here or Am I just trying to punch above my weight with A cheap plane? thanks Phil.
