chunkolini
I have been routing edges lately and getting fed up faffing about with G clamps on the edge of the bench.
So I had a look at what was around, and spottd these cheap clamps hanging on the wall, lopped the lug off the bottom that stops the screw bit falling off the bottom, drilled and slotted a hole in the bench. Invert the clamp and job done.
This is a bit close to the edge but works. I now have a line of slots all the way down the bench.
Edit, the other end of the clamp is of course under the bench, so I can remove it and use it as it was originally intended.
Chunko'.
Chunko'.
