If you aren't bothered about the sliding table this is significantly bettered by Axy's AC216TS as it has a larger table, proper cast iron trunnions and a better fence.Andrew1":2dlz69dc said:Hi does anyone own or have any views on the Charnwood table saw for a small Diy workshop.
Andrew1":1s0vevm3 said:Hi Bodgers, thanks for coming back. I had discounted the AXy as it looked tiny when you view it without checking the dimensions, bit daft on my end. The sliding table, not sure that gives me much for my intended use. Typically looking to cut to size panels for cabinets, infrequently, and trimming up boards after being ripped down with CS.
transatlantic":26yp8a2b said:Andrew1":26yp8a2b said:Hi Bodgers, thanks for coming back. I had discounted the AXy as it looked tiny when you view it without checking the dimensions, bit daft on my end. The sliding table, not sure that gives me much for my intended use. Typically looking to cut to size panels for cabinets, infrequently, and trimming up boards after being ripped down with CS.
The table is quite small. Only 400mm wide, where as most site saws are around 600mm wide (excluding extensions)
Bodgers":1xxjmko5 said:transatlantic":1xxjmko5 said:Andrew1":1xxjmko5 said:Hi Bodgers, thanks for coming back. I had discounted the AXy as it looked tiny when you view it without checking the dimensions, bit daft on my end. The sliding table, not sure that gives me much for my intended use. Typically looking to cut to size panels for cabinets, infrequently, and trimming up boards after being ripped down with CS.
With the supplied tables, width is actually 695mm. You have to fit the right table as well as the fence is dependent on it.
transatlantic":385zpni3 said:I was comparing table size alone which is the important part really, and what you're paying for
Bodgers":2z9v9f8m said:transatlantic":2z9v9f8m said:I was comparing table size alone which is the important part really, and what you're paying for
Cast iron + sheet steel vs cast alloy + a gap + extension slider thingy...take your pick![]()
Register today and take advantage of membership benefits.
