Changing table saw blade
guyos
6 May 2005
East Sussex
Hello
Can someone please tell me
To change my table saw blade, which way do I undo the nut, clockwise or anti clockwise?
guyos
Inspector
Nyuck, Nyuck, Nyuck!
18 Jun 2006
Saskatoon, SK., Canada
Easiest way to remember is to stand in the normal cutting position, hold the shaft/blade and pull the wrench on the nut towards you.
sunnybob
wysiwyg
11 Oct 2014
cyprus
Depends which side of the blade the motor is.
When the blade is spinning, it tightens itself up, so the nut /bolt / whatever has to turn the same direction as the blade.
Inspector
18 Jun 2006
That's why I said to turn the nut towards yourself. It doesn't matter which way motor is positioned. :wink:
