wobblycogs
I've got a slightly unusual telephone wiring problem and I'm wondering if anyone has a good solution.
Our phone line comes in on the ground floor in the hall but I need the ADSL router (the only thing on the line) in the office which is two floors up. Since there was no simple direct route between the two points I ran a piece of Cat5 from the master socket up to a slave in the office. Compared to the shorter Cat3 that I was using I got an extra 2Mb/s download speed so I was pleased with the result. The problem I now have though is that need to terminate the cable in a different place in the office - I'm building a server cupboard so it makes sense for the phone socket to be in there.
Pulling the cable back out of the office and running it to the cupboard is not an option, I'd have to take half the office to pieces to move it. Running a new cable all the way to the ground floor and across the house might be possible but it would be a huge job so that's out too.
The solution I'm planning is to cut the existing Cat5 cable outside the office and join a new run of cable to it. What I want to know though is the best way of joining the cable without harming the data rate too much. If possible I'd like to make it a Y joint and keep the old phone socket working but I don't care if that socket goes dead. My plan is to cut, pair back and solder each wire maintaining as much twist as possible. I'd rather a punch down extender but, unsurprisingly, I can't find anything like that. I wonder if I'd get away with a slave / master socket and punching down three wires into each point?
Annoyingly, the joint will have to be under the floor but I don't suppose the inspection requirements of mains wiring apply to telephone cable.
