Castors for kitchen work table
Fred Page
27 Sep 2004
Kington, Herefordshire, UK
I have a client who, having provided a design for a kitchen work table on castors, has also supplied the castors. These are of very good quality but are fixed by four corner screws. Yes, you've guessed the problem - screws into end grain, and dangerously near the edges of the legs! The legs are in 3 by 3 inch ash and the screws only half an inch from the edges.
I think that this is asking for trouble. Would friends on this forum agree and what alternatives are available? Should I insist that the client provides centre pillar type castors and would these be strong enough for a heavy work table? I wondered whether screw thread inserts might be an alternative (thinking these might be okay in end grain?) but cannot find a UK supplier. Any suggestions very welcome.
Fred
A
Anonymous
Guest
I have used nut inserts successfully in end grain (Screwfix) but I suspect you don't have enough room to drill for them? Could you drill smaller holes and fill with dowel, glued in, for the screws to go into?
Adam
10 Sep 2003
UK
Fred
Could you screw them to a plate, using machine screws, and in the centre of the plate, but a couple of really chuny screws up into the leg (i.e. much mroe central)?
adam
CYC
23 Jul 2003
Kildare, Ireland
Half an inch (12mm) from the edge sounds like enough to me using a long screw in a piloted hole, you could screw at a light angle toward the center of the leg. There are 4 screws per castor right? A kitchen worktable means no one will be sitting on it.
I am no professional, this is my humble opinion.
Fred Page
27 Sep 2004
Thanks, I will try out your suggestion as soon as I have a few spare inches of table leg. I'm not too happy about screws at an angle but the idea may well work. Otherwise I propose inserting suitable dowels at right angles to the screws - their end grain will of course show but this could be regarded as a design feature! Thanks again for your reply.
Fred.
