Gary_S
What do you wax/treat your cast iron tops with? I have Rose Oil which isn't cheap and doesn't feel as smooth as some waxed surfaces I have known.
WD40 IS also lubricant, IT IS a protective and penetrating) oil, and it is cheap.sunnybob":1dtf2nzx said:WD40 is a water dispersant (the clue is in the name) it is NOT a lubricating or protective oil.
Nah. Extremely unlikely. It isn't "grease" it's a hard wax. It can't "stain" anything. It's been top of the pops for generations because it is so effective, cheap, and trouble free.....
Candle grease is ok, but if you apply it too thick it can stain any good wood that is laid on the table.
I went into a modern bike shop recently. They had a huge rack of lubricants with possibly 20 to 30 marvellous high tech solutions to match every circumstance. Snake oil salesmen have taken over big time, just like the woodwork scene!Cheshirechappie":2mksd2p0 said:...
More seriously, has anybody tried one of those aerosol spray dry lubricants they sell in Halfords for bike chains and the like? I've no idea how long it would last, but as they're PTFE-based it should add a fair bit of slickness to a cast iron tables surface. Sort of high-tech paste wax.
I thought Briwax was old chip fat.phil.p":fixoq0ar said:It's one of the few uses for Briwax - disgusting stuff. I was advised years ago not to use WD40 on anything electrical as containing water it causes intermittent faults.
I agree with your point about fancy oils but actually beef dripping can make an excellent tool lubricant and rust preventative, as long as it's fully cleaned and dried.Jacob":3q69yzrj said:Why not... beef dripping?
Gotta disagree with almost all of that Bob, everything until you got to the KY.sunnybob":l22wzt5u said:WD40 is a water dispersant (the clue is in the name) it is NOT a lubricating or protective oil.
Any organic fat (chip, olive oil, etc.) will go foul after a short period of time.
Candle grease is ok, but if you apply it too think it can stain any good wood that is laid on the table.
KY jelly is water based, not a good idea, even if it did raise (hah) a smile.
As is mould release wax (for glass fibre work) - another good one. I used it for years on my router base as well. I could feel instantly when I'd done it.Myfordman":1axxqkrl said:I use hard car wax eg Simoniz on my CI tables. It only needs a trace.
Based on carnauba wax
It doesn't gel but if in pools it skins over. It has to be brushed on thin to avoid this. It doesn't "semi dry" it sets very hard (by oxidation, not by drying).ED65":t3rwm2ro said:.....
BTW I wouldn't agree with linseed being cheapest or best, most times I see it it's a darned sight more expensive than many other vegetable oils. And with the potential for gelling a drying or semi-drying oil isn't really ideal.
