Canopy Roof Matterial
Osvaldd
29 Sep 2018
NI
I'm planning to build a wee canopy/sitting area adjacent to the shed. It's pretty straight forward, 4” thick brackets from treated timber to hold the weight of the roof, and the sides will be done from treated t&g fencing boards. But I’m not sure what to use for the roof. I’ve seen some corrugated sheets at my local builders merchant, but they look like a farm shed. Any recommendations would be great.
Myfordman
AKA 9Fingers
19 Jan 2013
Southampton area
Marley Eternit synthetic slates look good and easy to fit. They are light and so no real extra consideration needed for roof loading with small areas like yours.
Robbo3
28 Jan 2012
Oxfordshire
Twin wall polycarbonate. It's relatively cheap, doesn't go brittle & you can walk on it without any fear of it breaking.
Myfordman
AKA 9Fingers
19 Jan 2013
Southampton area
They won’t work as I’ve just seen that your roof is too low a pitch for slates to seal.
Rubber would be a possibility.
samhay
10 Aug 2017
Peak District
What's your shed roof made of?
Can you use the same to make it look a bit more joined up?
Osvaldd
29 Sep 2018
NI
@samhay
50 year old slate roof, its now quite a bit weathered and full of moss, maybe I should look for used slates. But the problem with slates, they are heavy and I would need do make a proper roof structure, battens or whatever they are called, more complicated, more weight, more expense. etc.. hm time to think.
I quite like the idea of imitation roof sheets that sunnybob has suggested. If I can find something like that locally at a reasonable price I would go for it.
thanks Myfordman and Robbo3 too.
