Can you Joint on a router table?
nosuchhounds
4 May 2018
Derby
Ive seen plenty of vids about jointing on a table saw after thicknessing using a sled but I don't have a table saw (yet) and wondered if it can be achieved on router table with correct setup?
Mark Karacsonyi
4 Apr 2013
Budapest
You can edge joint on a router table. Have done it many times, it actually encouraged me to remake my fence (home made table). YouTube is a great source.
bp122
Expert at Jibber-Jabber
20 Aug 2019
Haddenham
Yes, you just need to offset the second half of the fence (outfeed side) by lining it tangential to the router bit.
Some router tables have this adjustment built in using either special inserts /shims /screw adjusters etc.
Kicked Back
28 Nov 2021
Bristol
As others have said, you can, but some router tables might make it harder than it's worth. An alternative way to joint edges with a router is to clamp something straight and flat (MDF, plywood) along the desired line and use a template bit. This has the added advantage that you can control where the edge ends up and so can apply it to both edges to make them parallel. The fence method isn't going to help you there.
Yojevol
Clocking on
29 Jan 2017
Cheltenham
But beware.
Ideally the infeed fence should be longer that the workpiece so that it is fully supported though the whole cut. Also if your edge is convex before cutting then there is a good chance it will rock against the fence and thus cause a curved outcome. If your initial edge is convex then make sure both ends are in contact with the fence at the start of the cut.
If you have a guide slot on your table use that and be independent of fences although you will have to fix a temporary guide batten to the underside of the workpiece
Brian
mikej460
19 Jan 2019
Daventry
But beware.
Brian
I've never tried it but I intend to, using a jig with a guide bar as you suggest
jonn
22 May 2015
Norway
Go the full hog, get a Leigh FMT Pro FMT Pro | Leigh FMT Pro Mortise Tenon Jig Leigh FMT Pro and you're set for life! Suddenly jointing is great fun.
And yes, I have one pluss a couple of Triton's biggest routers.
GrahamF
11 May 2015
Abergele and Portugal
If that Leigh jig is as complicated as my Super24 dovetail jig, more time will be spent reading the instructions than doing the job:D
