Hi anyone knows where and how much to buy a soft-start for my Dewalt table saw as it occasionally trips the circuit breaker on my household fuse board.
Is the circuit breaker a B or C rated breaker, such as B16 or C16? If it is a B breaker, try installing a C breaker that is better suited to handle the inrush of a motor starting. I use C breakers on all circuits that I dedicated to motors.
IS there a way?
my de walt 745 gives an almighty bang when it starts. No, it doesnt trip anything, but its almost frightening when it goes from zero to a million miles an hour in a tenth of a second. :shock:
Thats either an older or newer variant because of significant frame changes, but yes.
Its a great saw in a small space, but the start up noise sounds like its being swung over by a shotgun cartridge.
That is the saw I have, it is a good saw but a pain when it trips out. Thought I had it sorted when I switched the dust collection on after the saw but still cuts out.
Sorry, Dominik should not say that the saw was cutting out but what I meant was that the saw was causing the breaker in the consumer unit to trip. Following advice from MikeK, I called the electrician that installed the MCB and the cable to the shed and he is returning to fit a type C breaker. I will report back here if everything works out in case it helps others.
I had the same problem with my dewalt table saw. I use a starting current limiter. I can't post a link but if you Google Renkforce 622412 Starting current limiter you'll find the one I have. Works a charm.
Thank you Lambert that is very useful information to know will probably help Sunnybob too. If my new breaker does not work then at least I know I can get one of these.
I was kind of interested, but at 55 quid in the UK, plus shipping to me, I'm not that interested ta very much. :roll:
Mine has never tripped a fuse, it just starts very loudly. But as I wear ear protectors when I'm using it, I'll pass. 8) 8)
Quick update as promised the type C breaker fitted by electrition and no problem since even with my Camvack starting with 2 motors on and the table saw
