transatlantic
Boom!
I have an axle that looks like this :
When you press the button on the far left, it allows the ball bearings to move inwards, as to allow the axle to be slotted in place, and locked when the button is released.
The problem with mine is that I am missing one of the ball bearings. I assume they're held in place by the hole they're in being slightly less than the diameter of the bearing, and that they are somehow inserted from the inside.
So I'm guessing that if mine is missing a bearing, either the hole became too big, or the bearing got damaged (unlikely?) and fell out.
Assuming I can find a bearing of the right size (I've seen some assortments on ebay), is there anything I could do to mend it?
